HTML import as data table issue
I have been using the open() function for a HTML file. I'm now dealing with a column that has values such as "<2.4!".
when I use the open() function, it imports those values as "" in the data table.
However, when I do it using prompts in JMP, after opening the html file, I'm able to open the html file using 'Import table as Data Table' and the correct value of "<2.4!" is imported.
Is there a way to script this so that those values are not missing?
Thanks for any help
Byron_JMP
Re: HTML import as data table issue
That would be interesting to look at. Could you post a portion of your HTML file or a link to it?
Perhaps you might have hard coded that that column should be numeric somehow? Since it is now character, all of the non numeric values become missing.
It's not coded any where that the column must be numeric. Here's the code for opening I'm using:
//open the data as a jmp data table
dtcd = Open(
<html file>,
"invisible",
HTML Table( 1, Column Names( 3 ), Data Starts( 4 ) )
Below is a portion of the html file:
Data
62.6
146.1
15015.8
17430.1
8304.4
1097.3
254.6
22.9
7363.7
7445.8
4011.8
54.0
0.7
6.5
3218.3
3254.2
2954.7
2437.0
<3.2!
<3.2!
1514.6
Jeff_Perkinson
Thanks for posting it as a table here. That means we can try importing it from here.
What is the result from this JSL for you?
Open(
	"https://community.jmp.com/t5/Discussions/HTML-import-as-data-table-issue/m-p/270810#M52714",
	HTML Table( 1, Column Names( 0 ), Data Starts( 1 ) )
For me the column imports as a character column and all the values are there.
-Jeff
That worked for me as well with the column as character.
There actually is another level of complexity since the original file is an html file that is saved in excel with an html extension (automated data from a machine). So I do the following:
	FileList = pick file("Select Data");
	//Rename xls to html
		Basefile=Substr( FileList, Contains(  FileList, "/", -1 )+1  );
		basefile2=left(Basefile,length(Basefile)-3);
		Copy File(FileList,basefile2||"html");
		FileList_final = basefile2||"html";
That is done before I do the previous open function (here again for reference):
		dtcd = Open(
			FileList_final,
			"invisible",
			HTML Table( 1, Column Names( 0 ), Data Starts( 1 ) ),
