JmpLearner1
Graphs in JMP
Hi everyone, I'm hoping you can help me produce certain graphs in JMP.
I'm using the Backgammon data set (Download the data set 2) from the case study library in JMP. I was able to do one-way anova and then t-tests. I then did a right click on the output and saved it as a new data table.
Can someone please help me produce similar graphs? Specifically the bar graph with the brackets.
PS I got this image from an online search.
I couldn't find any directions to follow from the online documentation, and would appreciate any help or guidance.
Thank you!
Re: Graphs in JMP
This blog post might be able to get you started Using JMP to create SuperPlots .
Re: Graphs in JMP
Those are called box plots.
https://www.jmp.com/support/help/en/17.2/?os=mac&source=application#page/jmp/box-plot.shtml
