Graphing standardized scores
How can I use graph builder to generate a chart showing standardized scores for a continuous variable across different levels of a categorical variable? Do I need to create a new column of standardized scores first, or can this be done within graph builder itself?
Thierry_S
Re: Graphing standardized scores
You should create a new column for the standardized scores and use that column in Graph Builder.
Best,
TS
Thierry R. Sornasse
