lala
Level IX
How to set color gradients for specified multiple columns stroke by stroke?
Thanks Experts!
dt=Open("$SAMPLE_DATA/Big Class.jmp");
ca="height1";w=Try(Length(as Column(Current Data Table(),ca)<<get name),0)>0;if(w<1,New Column(ca));Column(ca)<<Formula( height*1.1 );Current Data Table()<<run formulas;Column(ca)<<deleteFormula;
Re: How to set color gradients for specified multiple columns stroke by stroke?
Something like this?
dt = Open("$SAMPLE_DATA/SAT.jmp");
dt << Delete Columns({"% Taking (2004)", "X", "Y", "Population", "Latitude", "Longitude"});
l = (dt << Get Column Names("Continuous", "String"))[1::3];
c1 = {"Green", "Yellow", "Red"};
c2 = [];
c3 = [];
For Each Row(dt,
	r = Floor(Ranking Tie(dt[Row(), l])); // no idea what should be done with ties
	c3 = c3 |/ r`;
dt << Begin Data Update;
For Each({i, idx}, l,
	m = c3[0, idx];
	g = Loc(m, 1);
	y = Loc(m, 2);
	r = Loc(m, 3);
	Column(dt, i) << Color Cells({{"Green", g}, {"Yellow", y},{"Red", r}});
dt << End Data Update;
or like this
/*""" Gradient color cells rowwise (using whole data)
Author: jthi
Creation Date: 2025-06-08
Creation JMP Version: JMP Pro 18.2.0
l = dt << Get Column Names("Continuous", "String");
c = [];
For Each Row(dt,
	m = dt[Row(), l];
	mn = (m - Min(m)) / (Max(m) - Min(m));
	c = c |/ Heat Color(mn, "Cividis");
dt << Begin Data Update();
	cm = {};
	For Each({c, idx}, c[0, idx],
		v = Eval List({c, Eval List({idx})});
		Insert Into(cm, Eval List({v}));
	Eval(EvalExpr(
		Column(dt, i) << Color Cells(Expr(cm));
dt << End Data Update();
10 REPLIES 10
lala
Level IX
回复: How to set color gradients for specified multiple columns stroke by stroke?
AI
not work
dt = Current Data Table();
colRange = {9, 10, 11};
minVals = {};
maxVals = {};
For(i = 1, i <= N Items(colRange), i++,
    col = Column(dt, colRange[i]);
    minVals[i] = Col Min(col);
    maxVals[i] = Col Max(col);
get_cell_color = Function({col, r, c},
    s = col << get script;
    p = 0;
    For(i = 1, i <= N Arg(s), i++,
        If(Head Name(Arg(s, i)) == "Color Cells",
            p = i;
            Break();
    If(p != 0,
        L = Arg(Arg(s, p), 1);
        color = {};
        For(i = 1, i <= N Items(L), i++,
            If(N Row(Loc(L[i][2], r)) == 1,
                color = L[i][1];
                Break();
        Return(color);
        normalized = 0.5;
        If(maxVals[c] != minVals[c],
            normalized = (col[r] - minVals[c]) / (maxVals[c] - minVals[c]);
        red = Round(255 * normalized);
        green = 0;
        blue = Round(255 * (1 - normalized));
        Return(RGB Color(red, green, blue));
For Each Row(
        colIdx = colRange[i];
        col = Column(dt, colIdx);
        Eval(Parse(Eval Insert("Column(dt, ^colIdx^) << Color Cells({{get_cell_color(Column(dt, ^colIdx^), Row(), ^i^), {Row()}}})")));
Are you trying to color the cells on a row using color gradient?
No real idea what was requested here, but here is an attempt of a script to row wise gradient coloring
Author: jthi
cont_cols = dt << Get Column Names("Continuous", "String");
m = dt[0, cont_cols];
colors = Heat Color(mn, "Cividis")`;
idx = 0;
For Each({contcol}, cont_cols,
	For Each Row(dt,
		idx++;
		Column(dt, contcol) << Color Cells(colors[idx], Row());
wait(0);
write("\!NDONE");
View more...
lala
Level IX
cont_cols = {};
For( i = 1, i <= N Items( colRange ), i++,
	Insert Into( cont_cols, Column( dt, colRange[i] ) << Get Name );
mn = (m - Min( m )) / (Max( m ) - Min( m ));
colors = Heat Color( mn, "Green Yellow Red" );
idx = 0;
For Each( {contcol}, cont_cols,
	For Each Row( dt,
		idx++;
		Column( dt, contcol ) << Color Cells( colors[idx], Row() );
Ok.
But it seems that in this way, the entire three columns form a whole
It is not a single row of three cells that form a color whole.
Thanks!
lala
Level IX
Implementing line by line would be too slow
What are you trying to do?
lala
Level IX
The color change of each row is only based on the comparison of the values in the three columns of that row.
Thanks!
You have only three values for each row and wish to have just those three colors?
c2 = [];
c3 = [];
For Each Row(dt,
	c3 = c3 |/ r`;
	m = c3[0, idx];
	g = Loc(m, 1);
	y = Loc(m, 2);
	r = Loc(m, 3);
or like this
Author: jthi
c = [];
For Each Row(dt,
	m = dt[Row(), l];
	cm = {};
	Eval(EvalExpr(
