PhamBao
Graph changes when switching to JMP14
Dear all users,
I just install JMP14 and experience a slight difference compared to JMP12
For example,  the image below is from JMP12
When I use JM14 and drag the parameter in Freg, all the cell with 0 is transparent . This means that the graph only illustrates number 1 and 2.
Do you know how to make the graph to display number 0 as JMP 12 did.
Sincerely
XanGregg
Re: Graph changes when switching to JMP14
I suspect Graph Builder was aligning with stat platforms where freq==0 values are ignored. You should be able to get the old view by putting the variable into the color role instead of the freq role,
