I am trying to get my script to graph values that are not in a data table but are generated when the script is executed. The program starts with an import of data in two columns similar to this:
Position | FocusMetric |
0 | 120 |
-4 | 140 |
-8 | 165 |
-4 | 160 |
-0 | 130 |
I then fit a spline up/down the data and determine the offset between the two. The issue comes when I am trying to graph the data. The GraphBuilder doesn't find the variables because they are not in the datatable. Here is my code, everthing seems to work until GraphBuilder. I am trying to get a line graph of offset,splineEval, and a marker for the backlash,splineMin. Any other suggestions are appreciated, this is a new language for me!
//Setup arrays for creating spline over data
x = Index(-100,0,1);
offset = Index(-20,20,0.1);
//Determine position minimum index
rPosMin = dt << GetRowsWhere(:Position == ColMin(:Position));
//Create spline coeficients over up/down scan of data
splineUp = SplineCoef(:Position[1::rPosMin-1], :FocusMetric[1::rPosMin-1], 1);
splineDown = SplineCoef(:Position[rPosMin+1::NRow()], :FocusMetric[rPosMin+1::NRow()], 1);
//Create array of least squares
for( i=1, i<=length(offset), i++,
s[i] = Sum(Abs(SplineEval(x,splineDown) - SplineEval((x-offset[i]),splineUp))),
//Create spline coefficient over regressed data
si = SplineCoef(offset,s,1);
//Find minimum from regressed data and determine backlash
rSplineMin = Loc(SplineEval(offset,si) == Minimum(SplineEval(offset,si)));
backlash = offset[rSplineMin];
print(backlash);
GraphBuilder(
ShowControlPanel(0),
Variables(
X(offset),
X(backlash, Position(1)),
Y(Values(SplineEval(offset,si))),
Y(rSplineMin, Position(1))
Elements(Line(X(1), X(2), Y(1), Y(2), Legend(5)))
