natalie_
Graph Builder- remove data series
Hi again,
I have two sets of x and y data.  Using the graph builder, I drag X1 to group x on the bottom and Y1 on group y on the left.  Then I drag X2 to group x on the bottom, and Y2 to group y on the left.  I dragged the second sets of data to the middle of the group so that it is not a split plot.
Now I have four sets of data, and I only want two.  In the legend it says, Y1/X1, Y2/X1, Y1/X2 and Y2/X2.  Is it possible to remove two of those series so that I only have Y1/X1 and Y2/X2?
pmroz
Re: Graph Builder- remove data series
Right click on the legend entry that you don't want (Y1/X2) and select Transparency.  Set the transparency to 0.  Then do the same for Y2/X1.  Then double-click the legend and uncheck the entries for Y1/X2 and Y2/X1.
Try running this code:
dt = New Table( "X1 Y1 X2 Y2", Add Rows( 5 ),
      New Column( "x1", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [1, 2, 3, 4, 5] )
      New Column( "y1", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [1, 2, 3, 1, 2] )
      New Column( "x2", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [2, 3, 4, 5, 6] )
      New Column( "y2", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( [4, 5, 6, 4, 5] )
dt << Graph Builder(
      Variables(
            X( :x1 ),
            X( :x2, Position( 1 ) ),
            Y( :y1 ),
            Y( :y2, Position( 1 ) )
      Elements( Points( X( 1 ), X( 2 ), Y( 1 ), Y( 2 ), Legend( 7 ), Jitter( 1 ) ) ),
      SendToReport( Dispatch( {}, "400", ScaleBox,
                  {Legend Model( 7,
                        Properties( 1, {Transparency( 0 )} ),
                        Properties( 2, {Transparency( 0 )} )
            Dispatch( {}, "400", LegendBox, {Position( {0, -1, -1, 1} )} )
pmroz
      Variables(
            X( :x1 ),
            Y( :y1 ),
                  {Legend Model( 7,
natalie_
Thank you!  I thought I just needed to remove it from the legend to remove it from the plot.
I will definitely be using that piece of code, too.  Thanks again!
