When graphing line plots at smaller frame sizes, data points seem to be omitted or summarised and detail lost. Attached are screenshots from the same measurement graphed four times, each time halving frame size, exported to PDF and then scaled up to the same height. As PDF is vector-based, the graphs should be scaled versions of each other, like the text of the axis title, but clearly they are not. The sampling frequency was 50, and when graphing data points, these 50 individual dots are all displayed (as seen furthest right). However, adding a line seems to cause loss of information. How can I get Graph Builder to simply "connect the dots" also at smaller frame sizes, not omitting any point or summarising measurements?
