natalie_
Level V
Graph Builder and Overlay
I am using the Graph Builder to create a wafer map of some leakage currents.  I've dragged the leakage current column over to the Overlay option.  It automatically gives 5 intervals/ranges; I've figured out how to edit the ranges, but I can't find how to add a new range.  Is there a way?  I prefer to use this over the "Color" option.
Thanks, Natalie
Re: Graph Builder and Overlay
Set the column property "Value Labels" for the overlay column, and you will be able to declare as many intervals as you want
ThuongLe
Right click on the column --> Column Properties --> Value Labels --> Check "Allow Ranges" --> Input your range --> Click "Add"
That should do it
Thuong Le
