Created:
Mar 20, 2026 04:00 AM
| Last Modified: Mar 21, 2026 10:16 AM
(490 views)
Graph Builder applies a clever scheme to determines which data points are actually processed.
Findings:
- objects (raw x/y values) outside the plot window are not displayed (e.g. x=1)
- objects with IDENTICAL x and y values are displayed as a single object (the first one)
- selected objects are displayed (even if it's a "second" object)
analogously: objects with a marker/color row state are displayed
- objects with different x values are displayed as multiple objects (tiny offsets like 1E-10 are enough)
- objects with different Y values are displayed as multiple objects (an offset of 0.01 is enough, 0.001 is not enough)
- objects with same x/y values, but different COLOR are displayed as multiple objects (sure: same holds for Overlay)
- The effects are nicely visible for Marker Draw Expr(), but the same should hold for standard Markers as well.
[For standard Markers, the functionality is difficult to detect, for Marker Draw Expr()it can have significant effects.]
