Graph Builder: Convert x-axis label from horizontal to vertical
I'm using Graph Builder (JMP 10) to group 3 items (WAT date, Lot#, and Wfr ID) on the same x-axis. In the attachment, only Wfr ID is vertical. Is there any way I can convert the horizontal labels of WAT data and Lot# to vertical ones for a clearer visualization? Thank you!
Best,
Han
Re: Graph Builder: Convert x-axis label from horizontal to vertical
I am not sure of all the axis options for Graph Builder with JMP 10 but try right-clicking on the X axis and select Axis Settings. Part of the dialog box should be for axis label rows. Orientation should be one of the aspects that you can control here.
