Subscribe Bookmark RSS Feed
Graph Builder Box Plot
geparker
Jan 6, 2015
When using graph builder and selecting a box plot, how do I make all the date points show and not just the outliers?
geparker
Jan 6, 2015
*data
julian
Jun 25, 2014
Hi geparker,
You can do this a few different ways. After generating the box plot in graph builder you can right click the graph, select add, then select points. Alternatively, you can add the points on top of the box plot by dragging the icon with points (in the pallete above the graph) on top of the graph. Dragging a visual (rather than clicking it) adds the visualization to the current plot (rather than replacing it).
I hope this helps,
julian
abrammer24
Community Member
Mar 9, 2017
Julian,
What if you have multiple sub-categories per main category like below? How do you get the points map to align with the box plot rather than just a jitter over the entire category?
I've been trying to figure this one out and starting to think JMP can't do this yet...
markbailey
Jun 23, 2011
Simply drag the column with the sub-categories to the top of the X axis to add it and nest it under the main category.
rabelardo
Mar 30, 2016
geparker​​,
Guess what's my JMP 12's Tip of the day (54 of 64)?
To overlay an element on an existing element in Graph Builder, press Shift then click the element icon that you want to overlay (image below).
julian​,
Thanks for your youtube channels! I'm learning a lot from them.
- Randy, JMP newbie
