ashwint27
Graph Builder Axis Box Background Colors Based on Value
For timeline/Gantt Chart visualization purposes, I would like to set different background colors on the Y-axis Axis Box based on the value inside.  For example, for "Category", I would like the "A" axis box to be one color, "B" to be another color, etc... I'm wondering if there is a Scripting option that could realize this.   In "Properties", there appears to be only one Background Color available to be set across all values in the axis box.
Re: Graph Builder Axis Box Background Colors Based on Value
I checked the Scripting Index for the messages that can be sent to an Axis Box and there does not appear to be any message to change the background color
Level XIII
I had the same idea some years ago : @ background color for nominal axis values
-> easy to implement, nice improvement for Graph Builder.
if you need this functionality, please follow the link and vote.
Level XIII
could help with nested x-Groups as well:
lwencx
可以设置Y轴参考线范围来定义背景色,用类别A,B....来设置颜色
Graph Builder(
Size( 876, 622 ),
Fit to Window( "Off" ),
Variables(
X( :Distance ),
Y( :Month ),
Y( :Day of Week, Position( 1 ) ),
Color( :Month )
Elements( Bar( X, Y( 1 ), Y( 2 ), Legend( 7 ) ) ),
Local Data Filter(
Add Filter(
columns( :Month ),
Where( :Month == {"Jan", "Feb", "Mar"} ),
Display( :Month, N Items( 12 ) )
Dispatch( {}, "月", ScaleBox,
{Add Ref Line( {-0.5, 6.5}, "Solid", "Black", "", 1, 0.25 ),
Add Ref Line( {6.5, 13.5}, "Solid", "Orange", "", 1, 0.25 ),
Add Ref Line( {13.5, 20.5}, "Solid", "Green", "", 1, 0.25 )}
Level XIII
The task:
... without Photoshop.
ashwint27
That would be for the background of inside of the graph itself (see picture in original message).  I am interested in coloring the AxisBox by different values.. I can color the entire Axis Box to be one color from Properties, but not by each individual value it seems.
