terapin
Graph Builder: Add 1:1 Line
Does anyone know how to add a 1:1 line to Graph Builder?  In the platform Fit Y by X there was a way to both fit the displayed data and show a 1:1 line.  I can't find how to do that in GB.  Thanks.
Re: Graph Builder: Add 1:1 Line
  1. Right-click on the canvas and select Customize.
  2. Click Add.
  3. Click Template and select Y Function.
  4. Change the function arguments to ( x, x ).
  5. Click OK.
Thank you for the answer. I have a question on how to label that line in the graph. How do you do it?
How to change the properties of the lines i.e. make it thicker, make it dotted, etc.?
Thank you. :D
11 REPLIES 11
  2. Click Add.
  5. Click OK.
terapin
Dang Mark,
That's a sweet solution.  I've never drilled around that part of GB before and I now see lots of other capabilities I can add to my graphs.  Thanks for sharing the tip.
In fact, the templates are just a convenience for new users. You can enter any graphics script you want and it will be evaluated by the frame box that is used for the canvas in Graph Builder.
The Customize command works in all of the frame box objects that are used to make plots in JMP...
gridge
Can you add a reference line like this in graph builder based on an equation? I have tried this but get an error. Y Function(y=350E^(-0.01*x));
You are missing the second argument that indicates the independent variable (x) in the formula. The first argument should be the valid expression for the function computation, not an equation.
It should look like this:
Y Function( 350*Exp(-0.01*x), x );
Thank you. :D
You should look in the Scripting Index under the Graphics() category.  There you will find Text(), Pen Size() etc.
     Help==>Scripting Index
There is also examples and documentation in the Scripting Guide
     Help==>JMP Documentation Library==>Scripting Guide
          Scripting Graphs
You can interactively change some of these characteristics by right-clicking in the plot frame and select Customize. The elements are listed on the left. For example, select a Line element and then the properties, for example thickness and color, appear on the right side where they can be changed.
JeffO
How about to put a slope limit for example +-3%. How can I do that?
