In a few months the era of programmers who know 100s of tricks will be over. It will be the era of programmers with creative ideas - maybe little programming skills - and the help of a Copilot : )
For pure python it works fine, but for Python in JMP you could for example contact the developers and ask if it is possible to implement that (or see if you could implement it yourself and make a request for it to be added to that extension).
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '845110' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '845110') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '845110') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
