Jakob
Getting my script to wait for platform to finish
Hi all
Hope you can help me with a large problem, my scrip is making a new window with a report header, then the user is putting in the columns for analysis and click OK. From that analysis I make a "Combined Data Table" but it always fails because the scrip it not waiting for the platform to finish. So my report generation stops.
I know the script works when I use a list for named columns or for a list of numeric columns, but that solution is not useful in this case.
Thanks Jakob
Script Below here
col = Current Data Table();
nw = New Window( "Measurering Report",
//Header for report
    nw1 = V List Box(
        Lineup Box(
            2,
            Outline Box( "Report Number" ),
            Text Edit Box( "", <<Set Width( 700 ) ),
            Outline Box( "Drawing Number" ),
            Outline Box( "KOM Number" ),
            Outline Box( "Supplier and Form Number" ),
            Outline Box( "Program Name" ),
            Outline Box( "Measurement Equipment" ),
            Outline Box( "Comments" ),
            Text Edit Box( "
            Outline Box( "Signature & Date" ),
            Text Edit Box( "
        Text Box( " " )
    dt = Current Data Table();
    obj = Variability Chart(
        Ignore Platform Preferences( 1 ),
        Model( "Crossed" ),
        Historical Sigma( 0 ),
        Connect Cell Means( 1 ),
        Mean of Std Dev( 1 ),
        Name( "Reduced Gauge R&R Report" )(1),
        Name( "Gauge R&R" )(6, 0.24),
        Name( "Gauge R&R Report" )(1),
        Misclassification Probabilities( 0 ),
        Variance Components( 0 ),
        Mean Plots( 1 ),
        Std Dev Plots( 1 ),
        Automatic Recalc( 1 ),
//if(OK button = run / No Ok wait(1));
dt1 = Current Report()[Outline Box( "Variability Gauge" )][Outline Box( "Gauge R&R" )][Table Box( 2 )] <<
Make combined Data Table;
Wait( 10 );
dt1 << Set name( "GRR1.jmp" );
Data Table( "GRR1.jmp" );
:Y << Set Name( "# Number" );
Column( 2 ) << Set Name( "Results" );
Column( 3 ) << Set Name( "Data" );
Data Table( "GRR1" ) << Split(
    Split By( :Data ),
    Split( :Results ),
    Group( :Name( "# Number" ) ),
    Sort by Column Property
dt2 = Current Data Table();
dt2 << Set name( "GRR2.jmp" );
Data Table( "GRR2" ) << Subset(
    All rows,
    columns( :Name( "# Number" ), :k, :Name( "Precision/Tolerance Ratio = RR/(USL-LSL)" ) )
dt3 = Current Data Table();
dt3 << Set name( "GRR3.jmp" );
Data Table( "GRR3.jmp" );
Column( 3 ) << Set Name( "PT Ratio" );
New Column( "PT Ratio Result",
    Character,
    "Nominal",
    Set Property( "Value Colors", {"Accepted" = 4, "Not Accepted" = 19, "Partly Accepted" = 41} ),
    Formula( If( :PT Ratio <= 0.3, If( :PT Ratio <= 0.1, "Accepted", "Partly Accepted" ), "Not Accepted" ) ),
    Color Cell by Value,
    Set Selected,
    Set Display Width( 200 )
Close( "GRR1.jmp", No Save );
Close( "GRR2.jmp", No Save );
Data Table( "GRR3.jmp" ) << Sort( By( :Name( "# Number" ) ), Order( Ascending ), Output Table( "GRR Report" ) );
Close( "GRR3.jmp", No Save );
Data Table( "GRR Report.jmp" ):PT Ratio << Format( "Fixed Dec", 20, 2 );
Data Table( "GRR Report.jmp" ) << Select Columns( all );
dt = Data Table( "GRR Report.jmp" );
Get Window( nw )[Text Box( 9 )] << Sib Append( H List Box( Outline Box( "GRR Report", dt << Get As Report ) ) );
nw[Table Box( 1 )] << Set Scrollable( 0, 0 );
wlist = Get Window List() << Get Window Title();
choose_window = Function( {},
    win = New Window( "Select a Report",
        <<Modal,
        hb = H List Box(
            Panel Box( "Select a report window",
                tcf = List Box( wlist, Max Selected( 1 ), chosen = tcf << Get Selected() )
    chosen;
chosen = choose_window();
w = Window( chosen[1] );
w << Report;
//you might need to scale the report to fit in the pdf page
w << Set page setup( margins( 0.2, 0.5, 0.2, 0.5 ), scale( .75 ), Landscape( 1 ), paper size( "A4" ) );
path = Pick Directory( "Select a directory" );
Set Default Directory( path );
w << Save Interactive HTML();
w << save pdf();
Data Table( "GRR Report" ) << save( "" );
nt = Current Data Table();
nt << Save();
Re: Getting my script to wait for platform to finish
I believe one of these approaches will help here:
How to button press and wait until action is finished
delay script execution until user input is provided?
/****NeverStopLearning****/
