This is how I'd do it in Oracle:
dbc = create database connection("<your connection string here>");
sql = "SELECT a.username
FROM all_users a
ORDER BY a.USERNAME";
dt = execute sql(dbc, sql, invisible)
close database connection(dbc);
schema_list = dt:username << get values;
close(dt, nosave);
tbl_list = {};
nw = new window("Schema Browser",
panel box("Schemas",
schema_cb = combo box(schema_list,
one_schema = schema_cb << get selected;
sql = evalinsert(
"SELECT a.table_name
FROM all_tables a
WHERE a.owner = '^one_schema^'
ORDER BY 1");
tbl_list = dt:table_name << get values;
tbl_lb << set items(tbl_list);
close(dt, nosave);
panel box("Schema Tables",
tbl_lb = list box(tbl_list, width(300), nlines(20))
