Here's a way to do it in code.
dt = New Table( "Untitled 3", Add Rows( 10 ),
New Column( "Column 1", Numeric, "Continuous", Format( "Best", 12 ),
Set Values( [1, 2, 3, 4, 5, 6, 7, 8, 9, 10] ) ),
New Column( "Column 2", Numeric, "Continuous", Format( "Best", 12 ),
Set Values( [., ., ., ., ., ., ., ., ., .] ) ),
New Column( "Column 3", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 4", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 5", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 6", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 7", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 8", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 9", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 10", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 11", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 12", Numeric, "Continuous", Format( "Best", 12 ),
Set Values( [., 0, ., ., ., ., ., ., ., .] ) ),
New Column( "Column 13", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 14", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 15", Numeric, "Continuous", Format( "Best", 12 ),
New Column( "Column 16", Numeric, "Continuous", Format( "Best", 12 ),
nc = ncols(dt);
for (i = nc, i >= 12, i--,
if (column(dt, i)[2] == 0,
show(i);
dt << delete columns(i);
