Chris_Rodrigues
Get entire contents of table script (including comments)?
I am trying to come up with a system to organize all the JSL scripts attached to my data table.  I want to insert a header in the comments at the top of each of my scripts.  It will look like this:
 * Script Name:		my script name
 * Script Category:		<<category>>
 * Author:				author name
 * Rev Date:			date
 * Purpose:			purpose
Inside of this header I will keep some metadata about each of the scripts.  For example, the "script category" field which is enclosed in angle brackets.  I want to be able to iterate over the scripts and manipulate them based on this metadata.
I know that I can obtain a list of all the scripts attached to my data table  like this:
dt = Current Data Table();
scriptList = dt << Get Table Script Names;
And then I can get the contents of a script like this:
scriptText = Char(dt << Get Table Property(scriptList[1]));
However, the scriptText does not contain any of the comments.  The header section is missing, so I can't access the metadata contained within those comments.
Is there a way to get the full text of a table script, including comments?
Chris_Rodrigues
Re: Get entire contents of table script (including comments)?
Thanks.  That's what I was afraid of - there's no way to programmatically access the comments except using some kind of ugly kludge on the comments side of things.
I did figure out a nicer-looking way to accomplish this.  I enclose the header comment block inside of JSL Quote() which tricks the JSL interpreter into keeping my comment block instead of deleting it.  So now I can read the category field and use it accordingly.
Here's my example script:
JSL Quote(
 * Script Category:		<<my category>>
 * Rev Date:			date
 * Purpose:				purpose
//this comment will be deleted
scriptText = Char(dt << Get Table Property("my script name"));
scriptCategory = Char(Regex(scriptText,"\<\<([A-Za-z0-9 \/]*)\>\>", "\1"));
Write("\!n" || scriptText || "\!n");
Write("\!n" || scriptCategory || "\!n");
And the output to the log:
JSL Quote(
 * Rev Date:			date
 * Purpose:				purpose
); dt = Current Data Table(); scriptText = Char(dt << Get Table Property("my script name")); scriptCategory = Char(Regex(scriptText, "\<\<([A-Za-z0-9 \/]*)\>\>", "\1")); Write("
"); Write("
my category
The only way that I know of to kluge my way around this is to place each comment into a dummy literal string
dt=current data table();
eval(parse("\[dt << new script("mysct",
comment="/**************************************/";
names default to here(1);
comment="// Here come more comments";
Chris_Rodrigues
JSL Quote(
 * Rev Date:			date
 * Purpose:				purpose
JSL Quote(
 * Rev Date:			date
 * Purpose:				purpose
"); Write("
my category
