Jackie_
Get Y axis column name from the variability chart
Is there a way to get the Y axis column name from the variability? I tried using get Y axis but doesn't work. Any suggestions?
dt = Open( "$SAMPLE_DATA/Variability Data/2 Factors Crossed.jmp" );
obj = dt << Variability Chart( Y( :Measurement ), X( :Operator, :part# ) );
ax = obj << get y axis;
Show( ax );
chart
Re: Get Y axis column name from the variability chart
Here is one way to get the Y column name
obj = dt << variability chart( Y( :Measurement ), X( :Operator, :part# ) );
// Parse the returned script to find the specified Y column
theYColumn = Word(
	1,
	Substr( Char( obj << get script ), Contains( Char( obj << get script ), "Y(:" ) + 3 ),
Column name is in at least four different places:
  • Your creation script
  • Three times in the report
    • Variability Gauge Analysis for Measurement
    • Variability Chart for Measurement
    • And Y-axis
Is there a specific reason to get it from Y-axis which is most likely the most difficult one?
dt = Open("$SAMPLE_DATA/Variability Data/2 Factors Crossed.jmp");
var = dt << Variability Chart(Y(:Measurement), X(:Operator, :part#));
yaxis_text = Report(var)["Variability Chart for Measurement", Text Box(1)] << get text;
theYColumn = Word(
	1,
    • And Y-axis
Jackie_
I am trying to create an interactive plot with radio buttons and column switchers. For that I need to get column names in the current Y axis VC to be able to replace columns in the column switcher
Jackie_
Thanks Jim and Jarmo!
