MuttonChops
Generating Graphs with a FOR loop and appending to a Lineup Box
JMP Pro 13.  I have several graphs that I'm generating with a FOR loop.  I'm attempting to append each looped graph to a lineup box.
-The loop uses a list (CleanList) that is generated at another point in the script to define the Group X in the graph.  But first I use that CleanName to create a filter and data subset so the graph for that loop uses only that data.
-I hid some of the basic graph stuff (Graph stuff here...) just to keep my script below easy to follow.
-I get a error (PMcntLUB/*###*/ <<append) in the log when I attempt to run it.
-Ultimately, this Lineup Box is inserted into a tab box with the other tabs being other components of my script.
-I'm not dead set on using a lineup box and am happy to try alternatives so long as I can end up with a column of graphs generated by my FOR loop that are embedded in the tab box.
PMcntLUB = Lineup Box( N Col( 1 ) );
For(i=1, i<=n items(CleanList), i++,
	CleanName = CleanList[i];
	dtCleanName = dtPMcntStack << Select Where(:Clean == CleanName) << Subset(Output Table( "dt"||CleanName ) << Show Window( 0 ););
	PMcntLUB << append(Graph Builder(
		Graph Stuff Here,
                Variables(X( :ProcessEndDateTime ),Y( :RFhours ),Group X(:Clean)),
More Graph Stuff Here), ); );
MuttonChops
Re: Generating Graphs with a FOR loop and appending to a Lineup Box
Wow, my problem was that I had a commented line with forward slashes instead of back slashes....face palm.  Corrected that and the script works.
MuttonChops
