uday_guntupalli
Level VIII
Generate a Matrix of Selectable checkboxes
All,
   Wondering what is the easiest way to generate a matrix of selectable checkboxes . So what i would like to be able to do is - generate a non- square matrix and pop it up for the user to select any position in the matrix the user would like. As long as the user can select multiple rows within a column and vice versa - it would be good to meet the need. Any help is appreciated.
Best
Uday
thomasz
Re: Generate a Matrix of Selectable checkboxes
Not a very elegant solution, but something like this may work:
lv={};
for(i=1,i<=4,i++, insert into(lv,""));
tCB="";
for(j=1,j<6,j++,tCB||="check box( (lv)),");
tCB=substr(tcB,1,length(tCB)-1);
eval(parse(eval insert("wind=new window( \!"Check boxes\!",
	H List Box(
	^tCB^))")));
@uday_guntupalli,
You can use a CheckBox() within a Table Box to create a table of check boxes.
nRow = 5;
nCol = 6;
// create a table box to contain everything
tbl = Table Box();
// add all columns with the given number of rows
For( i = 1, i <= nCol, i++,
	Insert Into( tbl, Check Box( Repeat( {" "}, nRow ) ) )
New Window( "Check Box Example",
	tbl,
	Button Box( "Show results",
		// initialize the result
		result = {};
		// loop through each row
		For( i = 1, i <= nRow, i++,
			// initialize the row list
			result[i] = {};
			// loop through each column getting values
			For( j = 1, j <= nCol, j++,
				result[i][j] = tbl[CheckBoxBox( j )] << get( i )
		// convert the list to a 2-d matrix
		result = Matrix( result );
		Show( result );
Here's what the window looks like:
And here's the result in the log with the above selected Check Boxes:
result =
[	1 0 0 0 0 0,
	0 1 0 0 0 0,
	0 0 1 0 0 0,
	0 0 0 1 0 0,
	0 0 0 0 1 0];
Justin
thomasz
lv={};
tCB="";
	H List Box(
	^tCB^))")));
uday_guntupalli
Level VIII
@thomasz,
       I think for my needs - it looks good. However, if I may - I have a couple of follow up questions:
1. Are the selected positions retrievable ? - If yes- can you kindly provide an example of how to retrieve that data ?
2. Is it possible to add a little more text around this window ? More like an X - axis label and a Y-Axis label
Best
Uday
@uday_guntupalli,
nRow = 5;
nCol = 6;
tbl = Table Box();
	tbl,
		result = {};
			result[i] = {};
		Show( result );
result =
[	1 0 0 0 0 0,
	0 1 0 0 0 0,
	0 0 1 0 0 0,
	0 0 0 1 0 0,
	0 0 0 0 1 0];
Justin
uday_guntupalli
Level VIII
@Justin_Chilton,
      1 follow up question I have is - Is it possible to add text on top of each column and at the beginning of each row  ?
      If so, what would be an  efficient way to do it ? Should each of them be wrapped in a text box ?
Best
Uday
You can add a heading to a CheckBox within a TableBox using the <<Set Heading message. You can also add row labels by placing a StringColBox as the first column in the Table Box.
nRow = 5;
nCol = 6;
// string col box for row labels
scb = String Col Box( "", {} );
// add labels to rows
	scb << Add Element( "row" || Char( i ) )
tbl = Table Box( scb );
	Insert Into(
		tbl,
		Check Box(
			Repeat( {" "}, nRow ),
			<<Set Heading( "col" || Char( i ) )
	tbl,
		result = {};
			result[i] = {};
		Show( result );
Window:
Justin
uday_guntupalli
Level VIII
@Justin_Chilton / @txnelson / @thomasz
     I have a follow up question, wondering if any of you could think of a way to do this. I am trying to generate the matrix of selectable boxes within a Panel Box. Here is the script, I have, wondering if you could guide as to why I am failing ?
InputsLoadBasic =
Expr(
		LB1 = Lineup Box( N Col( 2 ) );
		LB1 << Append(Panel Box( "Test",
									V List Box(
											V List Box(
														Text Box( "Arg1" ),
														NEB_arg1 = Number Edit Box( 2 ),
														Text Box( "Arg2" ),
														NEB_arg2 = Number Edit Box( 3 ),
		LB1 << Append(Panel Box( "Selectable Matrix Test",
									V List Box(
												Button Box("Enter Target Matrix",
															nR = 12;
															nC = 24;
															SCB1 = String Col Box( "", {} );
															For( i = 1, i <= nR, i++,
																SCB1 << Add Element( Char( i ) )
															TB1 = Table Box( SCB1 );
															For( i = 1, i <= nC, i++,
																Insert Into( TB1, Check Box( Repeat( {" "}, nR ), <<Set Heading( Char( i ) ) ) )
															ResMat = {};
																	ResMat[i] = {};
																	For( r = 1, r <= nC, r++,
																			ResMat[i][r] = TB1[CheckBoxBox( r )] << get( i )
															ResMat = Matrix( ResMat );
InputsLoadBasic;
InputsUnloadBasic =
Expr(
		V List Box(
					Align( center ),
					LB1,
					H List Box(
								Button Box( "OK",
											// Unload PV Prediction Details
											arg1 = NEB_arg1 << Get;
											arg2 = NEB_arg2 << Get;
											ResultMatrix = Matrix( ResMat );
										  )// end of button box
							 )// end of H List Box
				  )// end of V List Box
NW1 = New Window("TestUI",
					V List Box(
								InputsLoadBasic;
								InputsUnloadBasic;
The resulting UI looks like what I want, however, when I click on the  "Enter Target Matrix" button shown above, it does not do what I want. Can you please help
Best
Uday
msharp
I realize I'm late to the game, and hopefully you've already figured this out.  The main issue is you never displayed the Table Box in your code.  I believe the next issue is you analyze the table right after creating it.  I imagine you want to do this after the user has a chance to check the boxes.  Hopefully the below code is closer to what you are looking for.
InputsLoadBasic = Expr(
	LB1 << Append(
		Panel Box( "Test",
			V List Box( V List Box( Text Box( "Arg1" ), NEB_arg1 = Number Edit Box( 2 ), Text Box( "Arg2" ), NEB_arg2 = Number Edit Box( 3 ), ) )
	LB1 << Append(
			V List Box(
				Button Box( "Enter Target Matrix",
					nR = 12;
					nC = 24;
					if(!isempty(TB1),
						TB1 << Delete Box;
					LB1 << Append(TB1);
InputsLoadBasic;
InputsUnloadBasic = Expr(
	V List Box(Align( center ),
		LB1,
		H List Box(
			Button Box( "OK",
				ResMat = {};
					ResMat[i] = {};
				print(ResultMatrix);
NW1 = New Window( "TestUI",
	V List Box(
		InputsLoadBasic;
		InputsUnloadBasic;
