skram22
Generalized Estimated Equations or Logistic random-effects regression in JMP 16?
Looking to perform either of the above methods on binary clustered data with JMP. Would be ok with JSL code if available.
Re: Generalized Estimated Equations or Logistic random-effects regression in JMP 16?
Thank you for your question. In JMP 16, you can use this add-in:
https://community.jmp.com/t5/JMP-Add-Ins/Generalized-Linear-Mixed-Model-Add-in/ta-p/284627
(Note that we're working on adding GLMM in the next release of JMP Pro).
