Hello.
I have encountered the following issue while modeling with GLM/Poisson the data in the attached table (Response = Count, Regressor = X).
Data visual exploration suggests a clear relationship between X and Count, but comparison of AICc for model with X vs null model favors the Null model (just intercept). Scripts to reproduce the two models are embedded.
I believe I have found an explanation in the following note in the book by Burnham Anderson (Model Selection and Multimodel Inference Second Edition, 2002), but would like someone to confirm. If this is right, it is unfortunate that this has not been fixed in JMP.
One must be careful when using some standard software packages (e.g.,
SAS GENMOD), since they were developed some time ago under a hypothesis testing mode (i.e., adjusting χ2 test statistics by cˆ to obtain F-tests). In
some cases, a separate estimate of c is made for each model, and variances
and covariances are multiplied by this model-specific estimate of the variance
inflation factor. Some software packages compute an estimate of c for every
model, thus making the correct use of model selection criteria tricky unless
one is careful. Instead, we recommend that the global model be used as a basis
for the estimation of a single variance inflation factor c.
ps. using negative binomial in generalized regression (lasso), the min aicc model is the one with X as regressor, as one would expect.
Thanks,
Matteo
