CowDoc
Full parameter estimates in mixed model
I am running a mixed model for a continuous outcome using JMP Pro 17. In the output for the fixed effects parameter estimates, I have a 5-class categorical disease and the report shows the result for 4 of the 5 levels. How do I get or derive the Std Error for the parameter that is not displayed in the output report? (see the last row in the output copied and pasted below)
Fixed Effects Parameter Estimates
TermEstimateStd ErrorDFDent RatioProb>|t|95% Lower95% Upper
Intercept1022.568168.9938296.66.05<.0001689.98841355.147
305MEp0.3202140.00654110510748.95<.00010.3073930.333034
PrevLgp[1]-124.38513.32405102630-9.34<.0001-150.5-98.2698
PrevLgp[2]99.008214.12753904417.01<.000171.31838126.698
PrevLgp[3]153.981415.93062948379.67<.0001122.7575185.2052
PrevLgp[4]81.0656922.153441009703.660.000337.64522124.4862
PrevLgp_5+
CowDoc
Re: Full parameter estimates in mixed model
OK - I figured out a work around. In order to get the missing details, I changed the ordering of the categorical variables and then reran the model. Now, I can copy in the previously missing line because the referent population has changed.
statman
Possibly see here:
https://www.jmp.com/support/help/en/18.0/?os=mac&source=application#page/jmp/expanded-estimates.shtm...
CowDoc
Yes, I use the Expanded Estimates report when I run least sq means models/ANOVA but I don't think it is an option within the mixed models section. I am running a mixed model with 2 variables listed as random effects and others listed as fixed effects. However, I can't figure out how to get the std error/confidence interval for the unreported category.
CowDoc
