kachveder
From a Selection of Column Names, how do I modify the resulting column name list
Hi there,
Maybe you can help me figure out what I am doing wrong here.
I have the following toy data table:
I have been having some trouble with refining a list of character column names becoming from the following script.
//get unique column names
cols = Current Data Table() << getColumnNames(Character);
//del columns I don't want
DELCOLS = {"Column 5", "Column 6"};
unique_col_names = Associative Array(cols) << Remove(Associative Array(DELCOLS)) << get keys;
//make a pop-up window
nw = New Window( "Set a Value",
<<Modal,
Text Box("Set the character variable:"),
variablebox1_col_name = Radio Box( unique_col_names ),
H List Box(
//get all saved variable values when the user
//selects the OK button from the menu
Button Box( "OK",
	answers = Eval List({selected_var = variablebox1_col_name << get selected});
	nw << close window;
Button Box( "Cancel")
//change popup window size
<<Size Window(200,200)
What I am getting is the following in the resulting modal pop-up window.
I want the following pop-up window only to have the following:
I think my problem may have to do with a gap in my knowledge of associative arrays that I am having some trouble understanding completely, even though what the JMP scripting guide says about associative array keys and the remove from, remove, loc, and contains functions make sense.
I want to make sure that the columns that are left in the resulting list that I used in the model window can be renamed by the user in the original dataset, so the column names that I want to remove will stay the same. Also, the arrangement of the columns in the data table is the same, but the associative array rearranges the values in ascending order.
I used the following methods already, according to these forums, and there must be something that I am not seeing here because I am new to the JSL language.
- removing elements from a list remove elements in a list
- getting the column name from the column number and inputting the columns I selected into a list to be used. How to get column number from column name? (JMP)
I have attached the toy dataset file which includes the script that I have referenced above.
Re: From a Selection of Column Names, how do I modify the resulting column name list
Here is the way I would solve this issue
cols = Current Data Table() << getColumnNames( Character, string );
For( i = 1, i <= N Items( DELCOLS ), i++,
	Try( Remove From( cols, Contains( cols, DELCOLS[i] ) ) )
unique_col_names = cols;
	<<Modal,
	Text Box( "Set the character variable:" ),
	H List Box(
		Button Box( "OK", answers = selected_var = variablebox1_col_name << get selected ),
		Button Box( "Cancel" )
	<<Modal,
	H List Box(
kachveder
Thanks so much! It worked great in my project and I learned what the Try() function is too.
