AmirSS
Fractional Factorial - Understanding Aliasing Matrix
Hi all,
I would like to design a fractional factorial design. There are 4 factors.
I could afford only max 12 run, including 4 center points.
The highlighted 8 runs with resolution 4 is chosen.
Now, come to the question.
In terms of aliasing, the factor "GPN time" is known to have less significant impact. Therefore, the factor "GPN time" is afford to be aliased.
Above is the aliasing of effects generated by JMP.
How to read the alias matrix? Can someone please explain in simple term?
Is the factor "GPN time" aliased correctly?
Thank you in advance.
David_Burnham
Re: Fractional Factorial - Understanding Aliasing Matrix
In a resolution IV design main effects are not aliased with each other, nor with two-factor interactions.  There will however, be aliasing between two-factor interactions.  That is the aliasing being shown in the tabulation for "aliasing of effects".  For example, it is showing that GPN Pressure * GPN RF Power is aliased with GPN P% * GPN Time.  If you want you can click the red triangle and it will show you, for each term, what the aliasing pattern is (if any).
Based on this aliasing you would not expect to see any correlation between the estimates of the main factors and two-factor interactions, and that is confirmed by the alias matrix.  Zero indicates no correlation (because there is no aliasing).  The 1's that are appearing in the matrix relate to three-factor interactions.  If you click the red triangle under aliasing of effects it will also show you that all main effects are aliased with three-factor interactions.  As a general rule we worry about anything beyond 2nd order effects.
-Dave
David_Burnham
-Dave
"As a general rule we worry about anything beyond 2nd order effects." I believe David means to say as a general rule we DO NOT worry about anything beyond 2nd order effects. Certainly not in the early stages of sequential experimentation.
David_Burnham
Thanks for the spot @statman. Yes that is what I meant!
-Dave
