DZEMKE
Fourier Analysis
I have a data set of 2 parameter per second and would like to perform a Fourier analysis.
Both data tends to swing and I would like to see of the period of both is in phase or not.
DZ
Re: Fourier Analysis
There is no dedicated tool in JMP for the traditional Fourier analysis. The closest tool is the Functional Data Explorer in JMP Pro.
SamGardner
There is a JSL FFT() (Fast Fourier Transform) function that you could use to process the signal data and then do further analysis within JMP.
peng_liu
JMP Time Series platform can produce Spectral Density plots. Maybe that can be useful. Here is a screenshot.
