  • Due to global connectivity issues impacting AWS Services, users may experience unexpected errors while attempting to authorize JMP. Please try again later or contact support@jmp.com to be notified once all issues are resolved.
tajrida
Formula to remove first three characters from a alpha-numeric string
HI,
How do I remove "Thu" from the alphanumeric string "Thu 01/02/2020 10:42 PM" using and assigning a formulae, to a column.
I tried using below formulas and it doesn't work. what am I doing wrong?
1. left
2. right
3. word
4. substr
Mohammed Ahmed
Re: Formula to remove first three characters from a alpha-numeric string
I created a new column and placed this formula in it.
Substr(:Preparation date, 5)
and it worked without issue.  See my attached file
If the column you are reading from is actually a character column, and not a numeric column with a format applied to it, then the substring is what you want to use.  Make sure the column is a character column. and if so, the below will work
a="Thu 01/02/2020 10:42 PM";
b=substr(a,5);
The formula version of the above code if the original column is called "MyColumn"
substr(:MyColumn,5);
If not then you just need to change the format for the column
tajrida
Your suggestion is working fine for other character columns in the table BUT not for the column with specific format i.e.,
I also checked and verified column properties to ensure it is a "character" column.
Mohammed Ahmed
attach a sample data table please
tajrida
Thanks. Attached here is the test data file
Mohammed Ahmed
