Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
VR
VR
Formula for calculating averages of values in two consecutive rows
hi
 I would like to calculate averages of two consecutive values in separate rows and I have table with 1000 rows.  What formula can I use to do this?
Thanks
Re: Formula for calculating averages of values in two consecutive rows
if(mod(row(),2)==0,
mean(:raw_result,lag(:raw_result)),
This will calculate the average for every even numbered row and a missing value for each odd numbered row.
I think Col Moving Average should be able to do it Col Moving Average (jmp.com help)
From scripting index:
VR
VR
thanks for the quick response.  I used the formula below:
Col Moving Average( :raw_result, 1, 1, 0 )
96     96
93     94.5
100   96.5
110   105
How do i change the formula to get rid of the two underlined values?
Thanks again
if(mod(row(),2)==0,
VR
VR
Thanks so much, this worked.
The previous posted option will work great. You might also consider the Lag() function within the Mean() formula to reference the previous row, so it would read something like the below:
Mean( :Column, Lag( :Column ) )
VR
VR
Thanks, I will try this as well
