Onjai
Formula for Grouping months by season
I thought this was a rather simple formula to create, but found myself receiving formatting errors.
I have a column, character type, that contains months (October, November, December, and so on...).  I created a new column called "season" and wrote an IF(Contains(...formula to claasifiy if the month is October Then = fall,  and so on through the list creating the 4 categories (summer, winter, spring, fall).  However, the CONTAINS will not take the OR.
i.e.
If(Contains(:month, "October" | "November"), "fall", Empty())
What am I missing?  Any assistance would be appreciated.
ian_jmp
Re: Formula for Grouping months by season
Take a look at the 'Match()' function in 'Help > Scripting Index'.
ian_jmp
Onjai
Ian,
Worked fine!  Nice and clean.
Thank you and the rest of the fine folks in the jmp community.
Cheers!
If(Contains(:month, "October") | Contains(:month, "November"), "fall", "")
The above is the correct syntax for the approach you were taking.  However, Ian's approach is a more readable, and therefore more proper method
pmroz
You can search a column for a list of values.  Here's a formula that uses that approach.
dt = New Table( "test", Add Rows( 12 ),
	New Column( "Month", Character, "Nominal",
		Set Values(
			{"January", "February", "March", "April", "May", "June", "July",
			"August", "September", "October", "November", "December"}
	New Column( "Season",
		Character,
		"Nominal",
		Formula(
			spring_list = {"March", "April", "May"};
			summer_list = {"June", "July", "August"};
			fall_list   = {"September", "October", "November"};
			winter_list = {"December", "January", "February"};
			If( Contains( spring_list, :Month ), "Spring",
				Contains( summer_list, :Month ), "Summer",
				Contains( fall_list,   :Month ), "Fall",
				Contains( winter_list, :Month ), "Winter",
dale_lehman
As Jim points out, the sytax requires that the OR statement repeat the column = within the statement.  Match does work better, but why not just use the column Recode utility (which will produce the match formula)?
