- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
- Report Inappropriate Content
For-Loop doesn't respect arguments...?
Hi there,
can anybody explain why my for-loop below does not start with i=4 and does not end after i>250?
For ( i = 4 , i= i+12, i < 250,
The loop does as required and gives me correct results for i=16,28,40 etc etc. Only --- I don't get results for i=4. First results come for i=16. And the loop never ends. The script crashes when i reaches a value beyond my data limits (somewhere around 1800). I've written plenty of loops by now, but never had this issue?
Cheers,
Kofi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: For-Loop doesn't respect arguments...?
I think your second and third arguments are switched, maybe try this:
For ( i = 4 , i < 250, i = i+12,
If that doesn't work, you might check whether your iterator variable is used in the loop. You can ensure this is not a problem be adding a local context for that variable, like this:
For ( i = 4 , i < 250, i= i+12,
write( "Starting iteration " || char(i) || "\!n");
local( {i},
... i = 1 ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Please open Help --> Scripting index, search for "for" and find the enclosed example.
You see, that arguments need different order.
Also when hover over the command "for" you see the syntax, JMP expects.
s = "";
For( i = 1, i < 10, i++,
s ||= " " || Char( i )
Trim( s );
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
local( {i},
... i = 1 ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Ouch! This is quite embarrassing. It's seems I couldn't find the forest because of all the trees around me...!
Thanks nevertheless. Tells me that I've become rusty with my scripting routine.
Cheers,
Kofi
