Jackie_
Flagging Site to site variations
Is there a way to flag test parameters with site-to-site variations?
I am aware of looking at the variability chart, but I am exploring ways to identify statistically and implement using jsl which would make analysis faster.
The thought is to create a column that indicates if the test parameter has site-to-site variations. Any suggestions?
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
Thanks,
matth1
Re: Flagging Site to site variations
Not sure if I understand exactly what you want, but you could use the builtin Oneway platform and extract the means comparison results? Something like this:
names default to here(1);
dt << New Column( "PM_L1_Modified", set formula( If( :SITE == 1, :PM_L1 + 1, :PM_L1 ) ) );
cols1 = dt << get column names( Continuous );
For( j = 1, j <= n items( cols1 ), j++,
	ow = dt << Oneway(
		Y( cols1[j] ),
		X( :SITE ),
		All Pairs( 1 ),
		Comparison Circles( 0 ),
		Invisible
	level1 = (Report( ow )["Means Comparisons", "Comparisons for all pairs using Tukey-Kramer HSD", "Ordered Differences Report",
	String Col Box( "Level" )]) << get();
	level2 = (Report( ow )["Means Comparisons", "Comparisons for all pairs using Tukey-Kramer HSD", "Ordered Differences Report",
	String Col Box( "- Level" )]) << get();
	pval = (Report( ow )["Means Comparisons", "Comparisons for all pairs using Tukey-Kramer HSD", "Ordered Differences Report",
	String Col Box( "p-Value" )]) << get();
	ow << close window();
	p_count = 0;
	For( i = 1, i <= N Items( pval ), i++,
		If( pval[i] < 0.05,
			text = Substitute( "For __col__, sites __l1__ and __l2__ are statistically different",
				Expr( __col__ ), cols1[j],
				Expr( __l1__ ), level1[i],
				Expr( __l2__ ), level2[i]
			Print( text );
			p_count++;
			// Do stuff here
	if( p_count == 0, print( char( cols1[j] ) || ": no statistically different sites" ) );
Then you'd get output like this:
"PM_L1: no statistically different sites" "P1: no statistically different sites" "M1: no statistically different sites" "For PM_L1_Modified, sites 1 and 5 are statistically different" "For PM_L1_Modified, sites 1 and 2 are statistically different" "For PM_L1_Modified, sites 1 and 4 are statistically different" "For PM_L1_Modified, sites 1 and 3 are statistically different"
I had to create a new column as none of the parameters in Semiconductor Capability seem to have a SITE dependancy!
You can then do something interesting with the parameter and sites which are found to have statistically significant differences.
This is a very simple solution and could be optimised, or there may be a better JMP built-in way to get this info.
matth1
	ow = dt << Oneway(
		Y( cols1[j] ),
		X( :SITE ),
		All Pairs( 1 ),
		Invisible
	p_count = 0;
		If( pval[i] < 0.05,
			Print( text );
			p_count++;
			// Do stuff here
Jackie_
This is what I am looking for. Thanks @matth1
