vkessler
Fixed framebox size
Hi everyone,
quite oftten we are using the graphbuilder to generate wafermaps. Usually we are showing many wafers side by side using the "wrap" function. Then we get something like this:
In this case we are having 16 boxes, each one displaying a wafer. Ths size of the boxes is normally adjusted automatically.
My question is, if there´s a way to set and fix the size of the boxes?
Thank you very much!
vkessler
Re: Fixed framebox size
Thanks for your reply. Indeed, the mentioned size function helps to fix the overall size of the Gaph Builder. However, we actually thought about fixing the size of a single frame box within the Graph Builder, so that the frame box size would stay constant regardeless of the actual number of frame boxes.
I read along here and played a little bit with our code.The solution turned out to be like this:
1. Make a reference to the Graph Builder: gb = Graph Builder(...
2. Build a report: rgb = gb << report;
3. Send a message to the specific Frame Box: rgb[Frame Box(1)] << Frame Size ( 200, 100);
Here is a snippet of the actual code:
gb = Graph Builder(
    //Size( 400, 400 ),
    Include Missing Categories( 1 ),
    Title Fill Color( "Light Yellow" ),
    Title Frame Color( "Light Yellow" ),
    Level Fill Color( {239, 237, 190} ),
    Level Frame Color( "Light Yellow" ),
    Variables( X( :PosX ), Y( :PosY ), Wrap( :Quelle ), Color( :ChipCode ) ),
    Elements( Points( X, Y, Legend( 5 ) ) ),
        Dispatch(
            "PosX",
            ScaleBox,
            {Min( -15 ), Max( 70 ), Inc( 10 ), Minor Ticks( 0 )}
        Dispatch(
            "PosY",
            ScaleBox,
            {Min( -0.109291571319602 ), Max( 50.1092915713196 ), Inc( 10 ),
            Minor Ticks( 0 )}
        Dispatch(
            "400",
            ScaleBox,
            {Legend Model(
        Dispatch(
            "graph title",
            TextEditBox,
            {Set Text( "Chips" )}
        Dispatch(
            "400",
            LegendBox,
            {Set Title( "Chipse" ), Position( {0, 1, -1, 2, 3, 4, -1} )}
        Dispatch(
            "Graph Builder",
            FrameBox,
            {Background Color( 32 ), Marker Drawing Mode( "Normal" )}
        Dispatch(
            "Graph Builder",
            FrameBox( 2 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 3 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 4 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 5 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 6 ),
            {Background Color( 32 ), Marker Drawing Mode( "Normal" ) }
//gb << Show Tree Structure();
rgb = gb << report;
DaveLee
You could use the Size command to control the Frame size.  Below I used the Semiconductor.jmp dataset in CareerBuilder to fit NPN1 by Lot ID with a specified size.
Graph Builder(
    Size( 499, 516 ),
    Show Control Panel( 0 ),
    Variables( Y( :NPN1 ), Wrap( :lot_id ) ),
    Elements( Points( Y, Legend( 17 ) ) ),
    SendToReport( Dispatch( {}, "X title", TextEditBox, {Set Wrap( 2 )} ) )
DaveLee
I meant to type Graph Builder. I don't know how CareerBuilder came out!  Oops!
vkessler
gb = Graph Builder(
    //Size( 400, 400 ),
        Dispatch(
            "PosX",
            ScaleBox,
        Dispatch(
            "PosY",
            ScaleBox,
            Minor Ticks( 0 )}
        Dispatch(
            "400",
            ScaleBox,
            {Legend Model(
        Dispatch(
            "graph title",
            TextEditBox,
        Dispatch(
            "400",
            LegendBox,
        Dispatch(
            "Graph Builder",
            FrameBox,
        Dispatch(
            "Graph Builder",
            FrameBox( 2 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 3 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 4 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 5 ),
        Dispatch(
            "Graph Builder",
            FrameBox( 6 ),
rgb = gb << report;
doob_qoop
thanks for share, it makes big help
