hogi
Level XIII
Fit model: disable/toggle effect
In the Fit Model Platform, under Effect Summary, one can remove and add effects.
Is it possible to "disable" an effect ("remove", but keep in the list, e.g. crossed out or grey).
The idea:
With the possibility to "disable" an effect, one could play with the report without big harm to the model.
hogi
Level XIII
Re: Fit model: disable/toggle effect
Byron_JMP
That's kind of a cool idea.
Right now in Effect summary, the removed terms disappear, but if they remained, with no stats of course, but were greyed out, that might be kind of nice.
I'm staff, but you could suggest that in the JMP Wish List (menu tab at the top of the window)
statman
What you can do is remove an effect, then undo and remove a different effect...
hogi
Level XIII
