Wantj43
Fit Y by X - how to perform a specific test on multiple resulting graphs.
When "Fit Y by X produces multiple is the a way to perform an additional test on all the results without repeating the command individually?
Thank you
Joe
Wantj43
Re: Fit Y by X - how to perform a specific test on multiple resulting graphs.
When "Fit Y by X" produces multiple images is there a way to perform an additional test on all the results without repeating the command individually?
Thank you
Joe
I apologize for not proof reading the original posting
Thierry_S
Hi Joe,
It is rather difficult to provide an accurate answer without additional details:
1) What type of data are you analyzing X and Y (continuous, ordinal, categorical)?
2) When you say "multiple images", are you referring to repeated plots of the same format or something else?
3) Are you analyzing multiple Ys, multiple Xs or both?
Assuming you are analyzing multiple Ys for a single X, you can broadcast commands from one analysis to all other plots of the same type by holding the CTRL key while applying the desired command (e.g. Compare Means, ANOVA...). With that said, considering your experience level on the forum, I'm guessing that your question might be about something more complex.
Best regards,
TS
Thierry R. Sornasse
Wantj43
Thanking every very much.
Joe
