johnm
Fit Y by X Title always include the "Bivariate Fit of " phrase; is there a method to exclude this?
The Fit Y by X has in the title the phrase "Bivariate Fit of " in the title.
Is there a method or setting preference that skips placing this phrase in the title?
(Scripting allows customizing the title, just was curious if there was another method.)
thanks,
John
Re: Fit Y by X Title always include the "Bivariate Fit of " phrase; is there a method to
The option that you are aluding to does not exist.  You will have to use the manual method, or use a JSL script.
I don't believe there is any selectable option that will change the behavior..  However, interactively, you can just click on the outline box, and change the title to whatever you want
johnm
Hi Jim,
ok. I could not find any setings that allow the 'Bivariate Fit of" to be excluded from the title.
The manual method you describe works on one graph at time.
One can build a script to customize the title line.
I was looking for a method that simply changes this default title "Bivariate Fit of" to be excluded, and have the title produce a "dep var by indep var  grouping1=a  grouping2=b, ...."
John
