29755
Fit Group Alternative
Hi all,
I am trying to plot a bivariate table with polynomial fit degree and used FIT GROUP. But the line color doesn't change with accordance to the group by column when it is being run but when it is individually run, the line color changes according to the group by column. I think it is being affected by the fit group, is there any alternative ways to arrange plots into groups from different data table in the same format in fit group?
Please help
data table("Stacked12") << Bivariate( Y(:HOURS STUDY), X(: TEST SCORE),
GroupBy( :NAME( "SEX" ) ), Fit Polynomial(2), SendToReport( Dispatch( {}, "Bivar Plot", FrameBox, {Row Legend( SEX, Color( 1 ), Color Theme( "JMP Default" ), Marker( 0 ), Marker Theme( "" ), Continuous Scale( 0 ), Reverse Scale( 0 ), Excluded Rows( 0 ))}) ))
Re: Bivariate Group by Line Color
Using your code, just changing the column references to continuous columns in the Big Class data table, I tested the script back to JMP 11, and could not replicate your findings.  What version of JMP are you using, and what operating system
My version of your script
// Open Data Table: big class.jmp
// → Data Table( "big class" )
Open( "$SAMPLE_DATA/big class.jmp" );
Data Table( "big class" ) << Bivariate(
	Y( :height ),
	X( :weight ),
	Fit Polynomial( 2 ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Row Legend(
				SEX,
				Color( 1 ),
				Marker( 0 ),
				Marker Theme( "" ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
