Brad_Park
Finding vertex of bivariate graph
Hi all,
I'm trying to get a vertex point from bivariate graph
as so far, I get the extract the parameter with script and calculate it by excel sheet.
I'm quite sure finding vertex function is included in JMP but I couldn't find it.
Is there any way to get vertex directly?
Thank you
<script that I used to extract the parameter>
dt = Current data Table ();
biv=Bivariate(
Y( :contrast_100cm ),
X( :Offset_Z ),
Fit Polynomial( 2, {Line Color( {212, 73, 88} )} ),
Where( :site == "Para#4" )
rbiv = biv << report;
rbiv[tablebox(4)]<<make data table("Parameter table");
Re: Finding vertex of bivariate graph
Or, another approach is to use Fit Model, use the Response Surface macro so that JMP sets the response surface attribute. Then you will get a response surface output that solves for the critical values.
I had JMP create this script with some data that I made up.
Fit Model(
	Effects( :Offset_Z & RS, :Offset_Z * :Offset_Z ),
	Emphasis( "Effect Leverage" ),
	Run(
		:contrast_100cm << {Summary of Fit( 0 ), Analysis of Variance( 0 ),
		Parameter Estimates( 0 ), Lack of Fit( 0 ), Scaled Estimates( 0 ),
		Plot Actual by Predicted( 0 ), Plot Residual by Predicted( 0 ),
		Plot Studentized Residuals( 0 ), Plot Effect Leverage( 0 ),
		Plot Residual by Normal Quantiles( 0 ), Box Cox Y Transformation( 0 )}
		Dispatch(
			{"Response contrast_100cm", "Whole Model"},
			"Summary of Fit",
			OutlineBox,
			{Close( 1 )}
		Dispatch(
			"Analysis of Variance",
			OutlineBox,
			{Close( 1 )}
		Dispatch(
			"Parameter Estimates",
			OutlineBox,
			{Close( 1 )}
		Dispatch(
			{"Response contrast_100cm"},
			"Response Surface",
			OutlineBox,
			{Close( 0 )}
Here is the part of the output that finds the critical value.
Dan Obermiller
As I have posted many times, the Send to Report() and Dispatch() arguments are intended for JMP to save customization. They are not intended for users. Of course, you can use them. But there are better ways.
It appears that you want to add the answer to the plot. This example illustrates how to do that.
// fit quadratic polynomial interpolating function
biv = dt << Bivariate(
	Y( :weight ),
	X( :height ),
	Fit Line
// get reference to report layer
rbiv = biv << Report;
// get parameter estimates
parm = rbiv["Parameter Estimates"][Number Col Box( 1 )] << Get As Matrix;
// compute x intercept
ans = -parm[1] / parm[2];
rbiv[FrameBox(1)] << Add Graphics Script(
	Text( { 52.5, 160 }, "X intercept is " || Char( ans ) )
8 REPLIES 8
JMP does not have a solver as such. But you are fitting a quadratic polynomial interpolating function so you only need to set the first derivative with respect to Offset_Z equal to zero and solve for Offset_Z. I assume that by "vertex" you mean the minimum or maximum of the function.
// example of data
dt = Current Data Table();
	X( :Offset_Z ),
parms = rbiv[NumberColBox( 1 )] << Get As Matrix;
// compute extremum
extremum = -parms[2] / (2*parms[3]);
Show( parms, extremum );
Brad_Park
Thank you for kind answer.
Because you explained each code by remark, It was easy to understand.
I was trying to modify your code to find out the x intercept in linear function.
but nothing was come out.
Actually I really don't know how "show function" works.
Could you please help me to solve this?
Thank you
The Show() function writes text based on its arguments to the Log window, which is not open by default. Select View > Log if you are using Windows or Window > Log if you are using Macintosh.
I modified the script to estimate the x-intercept, assuming that it exists in the real plane. It is just the quadratic solution for the roots.
// example of data
x = -5::5;
dt = New Table( "Non-Linear Data",
	New Column( "X", Numeric, Continuous, Values( x ) ),
	New Column( "Y", Numeric, Continuous, Values( x^2 - x - 12 ) )
	Y( :Y ),
	X( :X ),
	Fit Polynomial( 2 )
parm = rbiv["Parameter Estimates"][NumberColBox( 1 )] << Get As Matrix;
ans = parm[2]^2 - 4*parm[3]*parm[1];
x intercepts = If( ans > 0,
	(-parm[2] + { -1, 1 } * Sqrt( ans )) / (2*parm[3]);
Show( parm, x intercepts );
Brad_Park
Hi Makrbailey,
Can I ask for more things?
I slightly changed the script to solve linear function and it worked properly.
however, I found myself that checking the result through log is not convenient as much as checking through tree-box.
as for as I know, dispatch function is the right one to make a tree-box to report.
so I  changed the script as follows. however, it's not working.
and I want to get the ans for each site (there's 4 sites). so I've tried to do it but it also didn't work.
Could you please give me your hand to solve it
Thank you so much
-> My purpose
1. add ans of each site.
2. add ans to report.
-> My script
Y( :CALU_CALU_intr_cy ),
X( :OC offset Y um ),
Fit Line( {Line Color( {212, 73, 88} )} ),
by(:site),
rbiv<<dispatch(
{"ans"},
"ans",
framebox,
{marker size(3)}
Thank you
	Y( :weight ),
	X( :height ),
	Fit Line
Brad_Park
It worked
Thank you so much
Fit Model(
	Run(
		Dispatch(
			"Summary of Fit",
			OutlineBox,
			{Close( 1 )}
		Dispatch(
			OutlineBox,
			{Close( 1 )}
		Dispatch(
			OutlineBox,
			{Close( 1 )}
		Dispatch(
			"Response Surface",
			OutlineBox,
			{Close( 0 )}
Dan Obermiller
Brad_Park
Thank you for reply.
I tested the script and found that this is exactly what I was looking for.
(Even though I didn't understand the whole code )
but I found that the Offset_Z value which is calculated by response surface is slightly different from my manual calculation (by differential)
the difference was under 0.0003 so it was no big deal
Thank you again for your help
