Mikasa
Finding the maximum of a column by matching another column condition
Hi every one,
I have to find the maximum value in a column (:PMA Counter) after checking the condition in another column (: Condition). the condition column has "After" and "Before" characters for the different rows.
I want to pick those which are "After" and fin the maximum of (:PMA Counter) between them.  I already use the below script but it is not working and only give me the Max without considering the Condition column.
dt=Current table();
dt<<Select Where(Contains (:Condition ,"After" ));
dt<<New Column ("Current PMA Counter", Character,Nominal, Formula(Col Max(:PMA Counter)));
Re: Finding the maximum of a column by matching another column condition
The row Select is not honored by the formula.  Here is a way to handle what you need
dt << New Column( "Current PMA Counter",
	Character,
	Nominal,
	Formula( Col Max( If( Contains( :Condition, "After" ), :PMA Counter, . ) ) )
I mistakenly created the Current PMA Counter column as a character string, and it needed to be numeric.....the JSL below seems to work
names default to here(1);
dt=current data table();
	Formula(
		If( Row() == 1,
			x = Col Max( If( Contains( :Condition, "After" ), :PMA Counter, . ) )
			y = x,
			y = .
		y;
11 REPLIES 11
	Character,
	Nominal,
Mikasa
Thank you very much Jim
Mikasa
Can I have the Maximum only in the rows related to "After" rows?
I do not understand what you are asking for.
Mikasa
I meant only those rows that had "After" in the Condition column get the Max value in the Current PMA Counter column. Other rows remain blank.
Here are a couple of versions of the formula(They are not tested).  They differ in what the Col Max is based on
// formula where col max is based upon only rows with "After" in PMA Counter
// and the Col Max only appears in rows where PMA Counter has "After" in it
	Character,
	Nominal,
	Formula(
		If( Row() == 1,
			y = x,
			y = .
		y;
// formula where col max is based upon all rows
	Character,
	Nominal,
	Formula(
		If( Row() == 1,
			x = Col Max( :PMA Counter )
			y = x,
			y = .
		y;
Mikasa
Thanks, Jim
it is finding the value but for some reason does not show up in the column. THE current PMA Counter is all blank
can you attach a sample data table that you are applying this to?
Mikasa
You can see the data attached.
