Liranlev
Find the Highest "F ratio" by fit stepwise
Hello there,
I need help with find the highest "F ratio" by fit stepwise. For example I have two groups- {A,B,C} and {1,2,3}
I put the first group ({A,B,C}) in Y and put the second group ({1,2,3}) in "Construct model Effects".
I want JMP will give the best pair between each group based on "F ratio"
for example A-2, B-1, C-3
How can I do it quickly and easily? It give me a lot of tabl
Re: Find the Highest "F ratio" by fit stepwise
I think the Anayze > Screening > Response Screening tool might be what you are looking for. It allows you to put in many Xs and many Ys, then gives a sortable table and graphs (although the table has PValues rather than F Ratios). Sample data table attached.
Liranlev
Thank you Jed, it is exactly what I looked for!
