You can avoid converting the numbers to character and back like this:
result = {[-0.368200035870304], [0.049749270873994], [0.612391979268901], [1.15772787379131], [-0.10485383375963]};
Substitute Into( result, Expr( {} ), Expr( V Concat() ) ); // make a col vector
result = Eval( result );
Show( result );
//result = [-0.368200035870304, 0.049749270873994, 0.612391979268901, 1.15772787379131, -0.10485383375963];
// or
Substitute Into( result, Expr( {} ), Expr( Concat() ) ); // make a row vector
Show( result );
// result = [-0.368200035870304 0.049749270873994 0.612391979268901 1.15772787379131 -0.10485383375963];
The Vconcat or Concat functions concatenate matrices, vertically or horizontally. The SubstituteInto function operates on the expressions, converting the curly braces into a VConcat or Concat operator. If you look at result after the substitute, before the eval, you'll see it is still an expression:
Show( result );
result = [-0.368200035870304] |/ [0.049749270873994] |/ [0.612391979268901] |/ [1.15772787379131] |/ [-0.10485383375963];
where |/ is the VConcat operator. After the Eval, it is a matrix as shown in the comment. The matrix will be a col or row vector depending which concatenation direction is used.
Whichever approach you take, leave a comment in your JSL about what it does and why!
