robot
Find All Display Tree Elements
I would like to use JSL to get a list of all the objects within a display tree for scripting purposes.  Specifically, I would like to get a list of all the FrameBoxes within a window, and then add a graphics script to each.  Or better still, I would like to return a list of available FrameBoxes to the user, and then have the user select which graphics script to add.
How can I get a list of all the FrameBoxes in a window?  I would like to get a list that is in a form suitable for scripting, and not just view the Display Tree.  Is this possible?
14 REPLIES 14
robot
Re: Find All Display Tree Elements
Hi MS,
The problem appears to be that "parent << getTitle" does not yield a result for Graph Builder in JMP10.
My team will make due without this for JMP10.  Thanks for your help!
tova
I am trying to run this script, but I am getting the error message :
Send Expects Scriptable Object{1} in access or evaluation of 'Send' , node << /*###*/className/*###*/
ANy idea why or what I should do?
thanks
tova
I am trying to run this script, but I am getting the error message:
THanks,
Tova
What version of JMP are you using?
Are you running on a Windows box or on a Mac?
Could you please clear the log, rerun the script, and then include the entire log output in your next response?
vince_faller
This worked for me if you don't need all the other stuff Ian built in.  Don't know why it's returning lists of lists but I just select the first one.
dt = open("$SAMPLE_DATA/Big Class.jmp");
biv = (dt << Bivariate(Y(:height, :weight), X(:age)));
frame_list = biv << xpath("//FrameBox");
wait(2);
frame_list[1][1]<<Select;
wait(2);
frame_list[2][1]<<Select;
Vince Faller - Predictum
