shampton82
Filter Col Selector usage
I'm trying to use a Filter Col Selector but I can't get it to return the selected value.
names default to here(1);
dt = Open( "$SAMPLE_DATA/Blood Pressure.jmp" );
nw=new window("test", <<modal, <<return result,
			v list box(var1=Filter Col Selector(dt),
			H List Box( Button Box( "OK" ), Button Box( "Cancel" ) ))
In this example var1 doesn't return the column name that was selected.
Thanks for any direction on how to use this!
Steve
Re: Filter Col Selector usage
Here is one way to capture the value of the Filter Selector
			H List Box( Button Box( "OK" ), Button Box( "Cancel" ) )),
			var1<<set script(zippy=var1<<get selected);
 The variable zippy contains the selected values
shampton82
Thanks Jim!
I just noticed that the column list box that shows up does not default with the filter on, is there a way to have this option be turned on by the script vs using the red triangle?
I don't see a message that will turn the filter on, but I did not do a real exhaustive search. Take a look in the Scripting Index under the FilterColSelector and maybe you can find such.
