Filter Change Handler triggering even when no filter is changed
Just noticed that Filter Change Handler is triggering when just on hovering over graph and returning value -1. Simple example script here, run it, check log and hover over markers in the graph
dt = Open("$SAMPLE_DATA/Probe.jmp");
nw = new window("",
	Data Filter Context Box(
		H List Box(
			lf = dt << Data Filter(
				Local,
				Mode(Include(1)),
				Conditional,
				Add Filter(columns(:Wafer Number), Display(:Wafer Number, N Items(15)))
			gb = dt << Graph Builder(
				Size(534, 456),
				Show Control Panel(0),
				Variables(X(:R_RSICR_100X20), Y(:R_RPPBR_4X15)),
				Elements(Points(X, Y, Legend(3)))
f = Function({a},
	Print(a)
rs = lf << Make Filter Change Handler(f);
gb << On Close(
	Try(Close(dt, no save));
	rs = .;
Also when filter is changed it seems to trigger twice (but I would say this is to be expected with JMP).
Using JMP16.2 Pro and Windows 10.
David_Burnham
Re: Filter Change Handler triggering even when no filter is changed
David_Burnham
I have a post about this - I'll dig it out
-Dave
David_Burnham
