  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Filter Change Handler triggering even when no filter is changed
Just noticed that Filter Change Handler is triggering when just on hovering over graph and returning value -1. Simple example script here, run it, check log and hover over markers in the graph
dt = Open("$SAMPLE_DATA/Probe.jmp");
nw = new window("",
	Data Filter Context Box(
		H List Box(
			lf = dt << Data Filter(
				Local,
				Mode(Include(1)),
				Conditional,
				Add Filter(columns(:Wafer Number), Display(:Wafer Number, N Items(15)))
			gb = dt << Graph Builder(
				Size(534, 456),
				Show Control Panel(0),
				Variables(X(:R_RSICR_100X20), Y(:R_RPPBR_4X15)),
				Elements(Points(X, Y, Legend(3)))
f = Function({a},
	Print(a)
rs = lf << Make Filter Change Handler(f);
gb << On Close(
	Try(Close(dt, no save));
	rs = .;
Also when filter is changed it seems to trigger twice (but I would say this is to be expected with JMP).
Using JMP16.2 Pro and Windows 10.
David_Burnham
Re: Filter Change Handler triggering even when no filter is changed
David_Burnham
I have a post about this - I'll dig it out
-Dave
David_Burnham
