Subscribe Bookmark RSS Feed
Fill to end of column in script
cmjewart
Sep 6, 2013
I have a set sequence that I want to repeat to the end of a data table like you can do with the "Fill to End of Column" when you select rows where this can go on for an unspecified number of rows
I'm using the following:
NewColumn("Part", Character, Values({"1-B","1-B","1-B","1-D","1-D","1-D",
  "1-F","1-F","1-F","1-H","1-H","1-H","1-J","1-J","1-J","1-L","1-L","1-L",
  "2-B","2-B","2-B","2-D","2-D","2-D",
  "2-F","2-F","2-F","2-H","2-H","2-H","2-J","2-J","2-J","2-L","2-L","2-L"}
1 REPLY
ms
Jun 23, 2011
Try Repeat().
Two examples:
seq = {"1-B", "1-B", "1-B", "1-D", "1-D", "1-D", "1-F", "1-F", "1-F", "1-H", "1-H", "1-H", "1-J", "1-J", "1-J",
"1-L", "1-L", "1-L", "2-B", "2-B", "2-B", "2-D", "2-D", "2-D", "2-F", "2-F", "2-F", "2-H", "2-H", "2-H", "2-J",
"2-J", "2-J", "2-L", "2-L", "2-L"};
// Repeat sequence a predefined number of times
New Table( "example 2", New Column( "Part", Character, Values( Repeat( seq, 5 ) ) ) );
// Repeat sequence to fit an existing table
dt = New Table( "example", <<add rows( 400 ) );
dt << New Column( "Part",
  Character,
  Values(
  Repeat( seq, Floor( N Rows( dt ) / N Items( seq ) ) ) || seq[1 :: Mod( N Rows( dt ), N Items( seq ) )]
