robot
Create Associative Array from Column Values
I would like to create an associative array from column values.  I am curious if anyone in the JMP community has a clever solution.  I am using JMP10.  An example is below.
// For the following data table:
example = New Table( "Example Data", Add Rows( 27 ),  New Column( "Lot", Character, Nominal, Set Values(
{"A", "A", "A", "A", "A", "A", "A", "A", "A", "B", "B", "B", "B", "B", "B", "B", "B", "B", "C", "C", "C", "C", "C", "C", "C", "C", "C"}
) ),  New Column( "Test", Character, Nominal, Set Values(
{"Test1", "Test1", "Test1", "Test2", "Test2", "Test2", "Test3", "Test3", "Test3", "Test1", "Test1", "Test1", "Test2", "Test2", "Test2",
"Test3", "Test3", "Test3", "Test1", "Test1", "Test1", "Test2", "Test2", "Test2", "Test3", "Test3", "Test3"}
) ),  New Column( "Parameter", Character, Nominal, Set Values(
{"Param1", "Param2", "Param3", "Param1", "Param2", "Param3", "Param1", "Param2", "Param3", "Param1", "Param2", "Param3", "Param1",
"Param2", "Param3", "Param1", "Param2", "Param3", "Param1", "Param2", "Param3", "Param1", "Param2", "Param3", "Param1", "Param2",
"Param3"} ) ),  New Column( "Yield", Numeric, Continuous, Format( "", 16 ),
Set Values( [1, 1, 0, 1, 0, 0, 1, 0, 1, 0, 0, 0, 1, 0, 1, 1, 0, 0, 1, 0, 0, 1, 1, 0, 1, 1, 0] )
),  New Column( "Defect Code", Character, Nominal, Formula( If( :Yield == 0, :Test || "_" || :Parameter ) ) ) );
// I would like to create an associative array with key = Lot, and values = Defect Codes.  Please see example below.
// What is the best way to script this?
// As a bonus, is it possible to create an associative array with multiple levels (IE: Lot => Test => Parameter => Defect Code)?
Defects = Associative Array( example:Lot );
Defects["A"] = {"Test1_Param3", "Test2_Param2", "Test2_Param3", "Test3_Param2"};
Defects["B"] = {"Test1_Param1", "Test1_Param2", "Test1_Param3", "Test2_Param2", "Test3_Param2", "Test3_Param3"};
Defects["C"] = {"Test1_Param2", "Test1_Param3", "Test2_Param3", "Test3_Param3"};
// Thanks for the help!
robot
Re: Create Associative Array from Column Values
If anyone is curious:
Defects = Associative Array( :Lot );
currentkey1 = Defects << First;
For( i = 1, i <= N Items( Defects ), i++,
  values1 = Associative Array( :Test[example << Get Rows Where( :Lot == currentkey1 )] );
  Defects[currentkey1] = values1;
  currentkey2 = Defects[currentkey1] << First;
  For( j = 1, j <= N Items( Defects[currentkey1] ), j++,
  values2 = :Defect Code[example << Get Rows Where( :Lot == currentkey1 & :Test == currentkey2 & :Yield == 0 )];
  Defects[currentkey1][currentkey2] = values2;
  nextkey2 = Defects[currentkey1] << Next( currentkey2 );
  currentkey2 = nextkey2;
  nextkey1 = Defects << Next( currentkey1 );
  currentkey1 = nextkey1;
Show( Defects );
robot
I figured out how to create an associative array with key = Lot, and values = Defect Codes.
I am curious if there is any advice about associative arrays with multiple levels.  Thanks!
currentkey = Defects << First;
  values = :Defect Code[example << Get Rows Where( :Lot == currentkey & :Yield == 0 )];
  Defects[currentkey] = values;
  nextkey = Defects << Next( currentkey );
  currentkey = nextkey;
Show( Defects );
robot
Show( Defects );
