dzeke
Contour plot algorithm?
Can someone point me to a reference that describes what function JMP uses to define the contours on the Contour Plot platform?  I found this in tech help: JMP uses a method of triangulation and linear interpolation to generate the contours in the Contour Plot where a combination of three data points are used to generate a triangle. To see the triangulations, opt to "Save Triangulations". but is there somewhere that provides more details? I need to describe the process for a publication; reviewers are grumbling about me using a "black box" analysis.
Thank you.
XanGregg
Re: Contour plot algorithm?
Contour Plot uses Delaunay triangulation. The triangulation algorithm doesn't handle duplicates. For duplicate locations, the mean of the response variable at that location is used instead.
XanGregg
