Depending on the settings in the preferences, it's possible to import txt import - with point and comma .
"not possible" means: data can be imported but numbers will be interpreted as characters.
JMP can handle numbers much more efficiently than text. The bottleneck to import them as strings - an then convert them to numbers could be too narrow to get your 1-3GB into the computer memory.
With JMP 17(?) compact columns were introduced. This allows to store character columns (with repeating entries) much more efficient in the computer memory. But there could be a bottleneck to get the data from a csv file into the compact column.
If you want to load numeric data in a "grid", please have a look at hdf5.
JMP can import such files, but the functionality is restricted. Better load the data via Python.
